2003 Volkswagen Beetle trouble codes
52,364 MILES • 4 CYL • 2WD • MANUAL
TEW
i have 2 codes that come up and cause my check engine light to come on.....po 236 & po 238...poertrain codes for turbo charger boost system and circuit sensor voltage high.. could you tell me what i'l have to do to fix this problem...hopefully just some sensor re[placement.....it happens whenever the car has been killed by stalling with the clutch..thanks ...Tom
Apr 25, 2008 at 7:34 AM
2CARPRO JACK
  • 11,533 POSTS
Those are codes for the "air charge sensor" located on the intercooler (RF fender) unplug it and turn key on to check for ref voltage Term 1 - 3 should be 4.5 volts
https://images.2carpros.com/forum/automotive_pictures/1639_conn_1.png
beyond that it may be a bad controller or PCM or charge sensor if reference voltage is good
Apr 26, 2008 at 1:18 AM
