2003 Volkswagen Beetle Brake Bar Light on Trunk
2003 VOLKSWAGEN BEETLE
55,000 MILES • 4 CYL • 2WD • AUTOMATIC
NOREENLM
Hi: A couple of bulbs are out on the brake bar that runs across the top area of the trunk. How does one replace the bulbs that are out, in other words how to get into that area, take the brake bar off to replace the bulbs?
May 30, 2010 at 4:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You have to open the hatch and completely take the inside cover off. you will find a screw on each side of the light . remove the screws and unplug the electrical connection and replace bulbs
May 30, 2010 at 4:33 PM
NOREENLM
The answer was pretty accurate, no screws on each side of bar light, tabs instead, but the answer with the Saturn was a little off but we got it figured out. Do you take pay pal as I am not willing to make a donation otherwise. Thanks.
May 31, 2010 at 10:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You can donate via Credit Card through our Verified Merchant Authorize.Net OR yes, you can donate via Paypal.
Thanks for using 2CarPros.com!
May 31, 2010 at 11:00 AM
