2003 Volkswagen Beetle
2003 VOLKSWAGEN BEETLE
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
MKNEECE
I recently changed my alternator and now my battery is over heating. What do u think the problem is?
Aug 3, 2009 at 12:08 PM
DR LOOT
  • CAR REPAIR CONTRIBUTOR
  • 2,311 POSTS
There could be a couple of reasons why that's happening the first one is the battery may have been low therefore the new alternator was charging it up, have you checked the water level? make sure you only use distilled water, and fill it to the bottom of the inverted cone, the other reason could be that you have a defective alternator and the internal regulator has malfunctioned charging the battery or should I say over charging the battery to the point that it is getting hot.
Aug 3, 2009 at 6:33 PM
