2003 Volkswagen Beetle
13,800 MILES • 6 CYL • FWD • MANUAL
KIM HOLSTINE
EPC light on ; have had problem twice with it not starting dead but jiggled some wires on battery & it started up but now the EPC light is on. It's sunday nobody's open is it ok to drive for a couple of days..
Dec 13, 2009 at 4:04 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
This is the Electronic pedal control warning light, you have what is called drive by wire, that is there is no throttle cable but a sensor at the pedal giving percentage commands to the ECU for throttle response, you will need to see a dealer to get a scan to see what exactly is going on, but it should be ok to drive there, just keep driving to a min as if it fails you will have no throttle response and you may be stranded.
mark (mhpautos)
Dec 13, 2009 at 1:48 PM
