2002 Volkswagen Beetle Trunk Won't Close
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
ACTION567
The trunk on my 2002 VW Turbo Beetle was acting up several times by not closing. I would have to take my key and manually open the trunk and then close it. When I put my key into the trunk lock and turned it counter clockwise and clockwise it would make a noise. Well now my trunk will not close at all. I have tried putting my key into the trunk lock and turning it as before but it will only turn counter clockwise. It will not even try to turn clockwise. I really need to get this fixed. Do you know of a way to do this or do you think something like this would be covered under warranty?
Thanks so much.
action567
Mar 28, 2010 at 10:39 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the latch assembly is broken.You are most likely out of warranty at that mileage/age of vehicle.Shouldnt be too difficult to replace, my software doesnt give any instructions though.Lock/latch assemblies are usually pretty simple though if you look at it to see what needs to be done before ripping it apart
Mar 29, 2010 at 10:07 AM
