2002 Volkswagen Beetle engine cooling
2002 VOLKSWAGEN BEETLE
58,000 MILES • 4 CYL • FWD • AUTOMATIC
PHYLISCIAB
How do i replace the engine cooling system? My car's cooling system sensor is leaking and it won't stay in place. What should i do?
Aug 30, 2008 at 3:11 PM
OMARRUFO
  • 11 POSTS
not sure exactly where your leak is or what you mean by cooling system leaking.. but if it's the coolant temperature sending unit, it's a 5 minute or less job.. Oreilly's sells sensor for about 16 bucks including tax.... it's held in place by a plastic U clamp you simply pull out with a scredriver and then pull it out with some long needle point pliers so you won't drop it.. sending unit/sensor is rigth valve cover vaccum hose on right side of engine (between engine and airbox)... has a 4 pin connector..if you have stock one,, it's a black sensor.. new and better one is green.. heard people replacing it for slight improvement in gas mileage even when there was nothing wrong with stock one... good luck .
Sep 5, 2008 at 3:54 PM
