2002 Volkswagen Beetle BENT ROD
DKELLLSTER
Engine Mechanical problem
2002 Volkswagen Beetle Automatic 90000 miles
DURING A BAD RAIN STORM MY BEETLE'S ENGINE SEIZED. IT HAPPENED ABOUT 5 MONTHS AGO. WOULD THEIR STILL BE EVIDENCE OF WATER ANYWHERE? ALSO IF THE ROD IS BENT DOES THAT PROVE THAT WATER CAUSED THE PROBLEM? THANKS
Jul 14, 2008 at 1:55 AM
KHLOW2008
  • 41,812 POSTS
Hi DKELLLSTER,
If more than a certain amount of water enters the combustion chamber when the engine is running, it would cause the con rods to bend.
You cannnot hide the fact. Water in the engine would evaporate if the oil heats up when the engine is running, if engine not started, it is likely it would still be in the sump, below the oils if it is not already mixed up.
Jul 17, 2008 at 6:02 PM
