my dad change the thermostat and my car still leaks.
why
Nov 9, 2018 at 11:44 PM
(Merged)
OMARRUFO
MEMBER
I just changed mine as well..you gotta be careful when you replace that thermostat stay in place until housing makes contact with engine block..since nothing really holds thermostat and o-ring in place, if it moves out of place, it may not seal properly..
(Merged)
✓Experienced Mechanic
Replacing the thermostat isn't too difficult to do. Make sure you have a place to put the old coolant after it's drained. You don't want any animals drinking it.
To get you started, here is a link that explains how in general one is replaced. You can use this as a more detailed guide when doing the job. The directions specific to your vehicle are attached in the pics below.
