2001 Volkswagen Beetle LIGHT CHANGE
40,000 MILES • 4 CYL • 2WD • AUTOMATIC
GDMLM
How do you change the lightbulb for headlight? We've tried everything. The high beams work, but the low beam is out on left headlight.
Jul 15, 2009 at 12:26 AM
STEVEW84
  • 673 POSTS
There is a lever that you have to pull all the way and the headlight will slide out. If you have never done one then it is a bit of a PITA. My recommendation is to try to clean and lube the slides or take it to a shop.
Jul 16, 2009 at 4:59 AM
