2001 Volkswagen Beetle camshaft position sensor malfunction
2001 VOLKSWAGEN BEETLE
95,000 MILES • 4 CYL • FWD • AUTOMATIC
TPANNO
  • 5 POSTS
I am getting a P0340 camshaft position sensor malfunction. Does this mean sensor is bad or ecu system needs recalibration? I replaced a bad cylinder head.
Dec 11, 2008 at 2:14 AM
RACEFAN966
  • 5,029 POSTS
Ok I would not do to much yet as we need to test to see if it is bad or if there is a wire problem. So with that said do you have a digital multi meter? You do know where the sensor is right? Get back to me and we will go from there. Thanks and have a great day.
Dec 11, 2008 at 2:31 AM
TPANNO
  • 5 POSTS
I have had it off and looked at it. I do not have a digital multi-meter but will get one if necessary
Dec 11, 2008 at 2:47 AM
TPANNO
  • 5 POSTS
I have a digital multi-tester now.
Dec 11, 2008 at 6:54 AM
RACEFAN966
  • 5,029 POSTS
Ok what I need you to do is unplug the sensor and use you meter set on 20 volts unless it has a 12 volt setting and between term 1 and term 3 check voltage should read 4.5 volts with key on engine off. Here is a pic of the term and which pins you need to test between.
https://images.2carpros.com/forum/automotive_pictures/249564_Graphic_1.png
If this checks out ok then you need to replace the sensor and then go have it scanned and clear the codes. If you do not have a scanner call your local parts stores and find one that does a free scan and have them do it. Let me how this goes ok.
Dec 11, 2008 at 2:33 PM
