2000 Volkswagen Beetle windshield washer fluid not pumping
CCONTI
Electrical problem
2000 Volkswagen Beetle 4 cyl Two Wheel Drive Manual
no fluid coming out to wash front windshield.
I believe I checked the correct fuse. Can't find the pump to by pass the fuse to see if it is operable
Jan 10, 2010 at 12:44 AM
  • 55,612 POSTS
Hey CCONTI,
Please check the fuse first and then the nozzles to see if they are plugged. Then I would go for the pump motor becasue they have a high failure rate.
Here is a guide that will help you see what you are in for when replacing the motor.
https://www.2carpros.com/articles/how-to-replace-a-windshield-washer-pump
Please let us know what happens so it will help others
Best, Ken
Feb 5, 2017 at 7:30 PM
