2000 Volkswagen Beetle TURN SIGNAL
102,000 MILES • 4 CYL • FWD • MANUAL
MOHOGUE
WHEN I USE MY TURN SIGNAL OR HAZARD WARNING LIGHTS, THEY LIGHT UP BUT WILL NOT FLASH. THEY JUST REMAIN ON. I CANNOT FIND WHAT I USED TO CALL A 'STARTER'. ANY SUGGESTIONS ON FIXING IT?
Aug 7, 2009 at 9:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
flasher unit is faulty. The flasher unit is built into the Hazard Warning Light button. Just behind the push in part of the button, underneath is a bit where you can lever the entire switch out. Once removed, a new one can be slotted into place.
Aug 7, 2009 at 1:20 PM
MOHOGUE
THANKS SO MUCH. I WILL TRY THIS AFTER I GET THE PART. VERY HELPFUL
Aug 7, 2009 at 2:40 PM
