2000 Volkswagen Beetle leak in backside of engine
2000 VOLKSWAGEN BEETLE
152,236 MILES • 4 CYL • 2WD • MANUAL
JAMES PEREZ
i am experceincing a leak i have yet to find it replaced hoses and thermostat i have been unable to find it will you please help me on the right direction
Nov 8, 2008 at 1:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
I am assuming you mean a coolant leak..? Is your vehicle overheating? Do you see any coolant leaking around the water pump? If there is no visible leak than there is a good chance that your coolant is leaking into your engine. Check your oil to see if the oil level is higher than it should be or if the oil is watered down. A blown head gasket is usually the cause of this.
Nov 8, 2008 at 2:06 PM
