2000 Volkswagen Beetle Diagnostic code P0411
56,000 MILES • 4 CYL • 2WD • AUTOMATIC
SLEEPINGSUSIE
After my check engine light came on, Autozone checked and gave me this error code. The car is running fine, no noise, no leaks, no burning smell. My gas mileage seems to be going down, but then I may be looking for a problem there.
Can I fix this by myself? Do I need to take it into a dealer? How long can I drive with this problem? Would this potentially be covered under a warranty?
May 3, 2008 at 6:31 AM
BUZZSAW
  • 1,198 POSTS
[quote:72f3c1a5dc="sleepingsusie"]Engine Mechanical problem
2000 Volkswagen Beetle 4 cyl Two Wheel Drive Automatic 56,000 miles
Can I fix this by myself? Do I need to take it into a dealer? How long can I drive with this problem? Would this potentially be covered under a warranty?[/quote:72f3c1a5dc]
this is an EVAP code, you need to ck your gas cap, always tighten it with 3 clicks, code says purge flow problem. so if you havent replaced your gas cap or it is tightened right you will need to go to the dealer and have the EVAP sys checked out, it could bust the gas tank.
May 3, 2008 at 7:32 AM
SLEEPINGSUSIE
Thanks for the quick reply! Sounds a little scary, should I not drive it unitl it's checked?
May 3, 2008 at 10:39 AM
BUZZSAW
  • 1,198 POSTS
[quote:b926de529f="sleepingsusie"]Thanks for the quick reply! Sounds a little scary, should I not drive it unitl it's checked?[/quote:b926de529f]
its not scary, dont sweat it, but ck your gas cap
May 3, 2008 at 11:45 AM
SLEEPINGSUSIE
Thanks, I will. :)
May 3, 2008 at 3:34 PM
