2000 Volkswagen Beetle Coolant problems
TANAC1428
Engine Cooling problem
2000 Volkswagen Beetle 4 cyl Two Wheel Drive 80326 miles
How does a do it yourselfer bleed antifreeze out of the line?
Feb 23, 2008 at 1:11 PM
BLACKOP555
  • 10,386 POSTS
first on the top of the thermostat housing check if there is a bleed port, if not the easiest thign to do is to put the front end up on jack stands so the radiator cap is the highest part of the engine and start the vehicle and let it warm up till the thermostat opens then keep filling it till no more bubbles.
Feb 23, 2008 at 1:43 PM
