2000 Volkswagen Beetle 85,000 miles
My daughters V/W Bug: She called & said that the water light comes on and she has checked the coolant water level. Says that it is full. She stated yes that she (&her boy friend know where to properly check the level) Engine does not appear to overheat. She also says that the lite comes on as soon as she starts the car. even after sitting overnight. (could this be a stuck thermostat? She also says that she has a ABS warning lite, A brake warning lite, an enginewarning site and an airbag warning lite that all come on. Sounds like it could be an electrical problem or computer problem. Is there any simple things that could be common to all these warning indications that we can check or is this more likely major surgery????
Nov 15, 2009 at 6:04 AM
