2000 Volkswagen Beetle ALWAYS A DEAD BATTERY
2000 VOLKSWAGEN BEETLE
45,000 MILES • 4 CYL • 2WD • AUTOMATIC
BIPA
I HAVE A NEW BATTERY AND STILL THE BATTERY GOES DEAD, WHAT CAN CAUSE THIS, ? i HAD THE ALTERNATOR CHECKED AND IT WAS GOOD.
Oct 25, 2009 at 4:37 AM
  • 31,937 POSTS
Hi there,
You will need to get a current draw test done to check for a circuit that is open and causing this drain, connect an Amp meter between battery pos(+) and the pos(+) lead, with doors closed & key out check the current draw, if above about .45 Amps pull fuses one at a time to find the faulty circuit. try this next.
Mark (mhpautos)
Oct 25, 2009 at 2:38 PM
