1999 Volkswagen Beetle Replacing Rear Rotors
100,000 MILES • 4 CYL • FWD • AUTOMATIC
DISCODONKEY
Is the emergency brakes inside the rotors? and if so can i get the rotors off myself. if they are not inside the brake rotor how does the emergency brakes work work?
Jul 19, 2010 at 2:21 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes, the parking brake cable runs to the rear brake caliper and then uses it as the parking brake.
Jul 19, 2010 at 2:28 PM
DISCODONKEY
yes that helped some. so are there brake shoes inside the rotor like on the drum surface or do the brake pads for normal braking get used for emergency braking?
Jul 19, 2010 at 4:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you should have rear rotors, not drums? yes it uses the regular brakes as the parking brake.
Jul 19, 2010 at 11:05 PM
