1999 Volkswagen Beetle Missing a beat
1999 VOLKSWAGEN BEETLE
CHARES
Engine Performance problem
1999 Volkswagen Beetle Manual
My Beetle misses a beat on idling also when changing gear it loses revs also if you put you foot on the eccelerater to overtake it loses revs. Can you suggest a remedy as my car is in Spain at the moment.
Jan 12, 2010 at 1:10 AM
DR LOOT
  • 2,311 POSTS
it may be ignition related or fuel related problems do you have a check engine light on?
Due to the high volume of no responses to posted questions, if you have not resolved your issue and you need further assistance, please respond.
Jan 19, 2010 at 2:39 AM
CHARES
Thanks for your reply,I do not have any warning light showing. Cou;d it be spark plug problem or leads?
Jan 20, 2010 at 3:12 AM
DR LOOT
  • 2,311 POSTS
if it was a spark plug or a wire, you would have an engine light on with the code of misfire, I believe I would check the fuel pressure first, low fuel pressure or a plugged up fuel filter will not set an engine code. And the vehicle will act exactly as you are describing.
Jan 20, 2010 at 5:50 AM
