1999 Volkswagen Beetle car won't start
BLANZI0011
  • 1999 VOLKSWAGEN BEETLE
  • 4 CYL
  • 14,500 MILES
Car ran excellent until I shut the car off for work. 6 hours later tried to start car and would not start. Checked fuses and added fuel still no start what else should I try. Fuel pump or fuel pump relay?Do not smell gas when I attempt to start at engine comp. Please help !
Thursday, September 16th, 2010 AT 4:49 PM
Hi blanzi0011@comcast. Net, Welcome to 2carpros and TY for the donation
Do below to determine if its a fuel or spark problem and get back with me
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Thursday, September 16th, 2010 AT 6:11 PM
