1999 Volkswagen Beetle blinkers or turn signals
1999 VOLKSWAGEN BEETLE
61,000 MILES • 4 CYL • FWD • MANUAL
ELAINAWINE
My blinkers are not working. I can manually flip them back and forth to make them blink but even then they light up occassionally but most of the time it does nothing. What's wrong? Is the fuse or bulb -
Feb 6, 2009 at 2:20 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Need to inspect turn signal flasher. If it is OK, suspect faulty signal switch.
Thanks for using 2CarPros.com!
Feb 6, 2009 at 4:18 AM
ITOROSSIAN
What if the hazards are working perfect but the turning signals are not working properly??
should I replace the flasher or the switch in this case??
Thanks!
Feb 7, 2009 at 2:10 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The hazard lights have a seperate flasher. You have both a Hazard Flasher as well as a Signal Flasher. Need to replace Signal flasher first. It is cheap and easy to replace.
Feb 7, 2009 at 10:24 AM
