1999 Volkswagen Beetle Alternator?
1999 VOLKSWAGEN BEETLE
106,000 MILES • 4 CYL • 2WD • AUTOMATIC
HIJINK
I drove my car to work this morning with no problems and drove it to lunch this afternoon with no problems, and then tried to start it after a 45 minute lunch and it wouldn't start. The battery was dead. I was able to get a jump in order to get back to work and then the car wouldn't start again after I got off work. I got a jump and drove straight to my local PepBoys to get the battery replaced (it was still under warranty). After waiting at least an hour, I tried to leave with my new battery installed and suddenly the battery light icon was on and my headlights were flickering--something the repair tech didn't mention after he cleared me to leave. I went back inside and they tested the new battery, which was fine and told me it was my alternator and that I should come back tomorrow to get that replaced for $400. The car drove home the 2 mile distance or so just fine with the battery icon on the entire time (although the headlights did stop flickering).
I understand that the problem with my car is symptomatic of an alternator issue, but before I take it in to get the replacement, is it at all possible that the battery was improperly installed causing a connection problem with the alternator? Is there anyway for me to look into that myself before taking the car into the shop?
Sep 4, 2008 at 5:18 PM
2CARPRO JACK
  • 11,533 POSTS
Look at all connections to be sure they are tight, there is also a row of fuses on top of the battery box you can check.If you have a meter,start the car and test what the alt is putting out to the battery.Sometimes a bad battery can take out the alternator by making it over charge due to bad/shorted cell in the battery
Sep 5, 2008 at 12:43 AM
