1998 Volkswagen Beetle shifting problem
88,000 MILES • 4 CYL • 2WD • AUTOMATIC
EXIT2NONE
after an hour stop and go traffic transmission not able to shift from 1st gear into second anymore. Parking the car for 2-3h and driving again the transmission works again.
What could be the problem? How much does it cost to fix?
May 16, 2010 at 5:06 PM
  • 31,937 POSTS
Hi there,
You will need to get this transmission serviced and get a test and report from a trans specialist as there will have to be a few hands on test done to lock this problem down, you can go get a scan as there may be an electrical fault that has set a code in the ECU.
Mark (mhpautos)
May 16, 2010 at 5:53 PM
