1979 Volkswagen Beetle Front end
90,000 MILES • 4 CYL • 2WD • MANUAL
DORIS MCCLARY
I have a 1979 VW Convertible, and when I get to about 45 miles an hour the steering wheel shakes very bad. I have new tires, so I don't know what the problem is. Hope you can help. Thanks Doris
Aug 24, 2008 at 11:30 AM
  • 75,988 POSTS
Most tire/wheel imbalance problems will make themselves evident at speeds above 45 to 50 mph. A back-and-forth shimmy in the steering wheel means one or both front wheels are dynamically imbalanced, or a rim is bent
Could be due to an out-of-balance wheel a bent rim, an out-of-round rim or tire, an off-center wheel or hub, or a bent or imbalanced driveshaft? Sometimes the problem is worn shocks or a loose part in the suspension or steering linkage.
Aug 24, 2008 at 11:49 AM
