1977 Volkswagen Super Beetle 1977 Super Beetle won't start
10,800 MILES • 4 CYL • 2WD • MANUAL
STAN7_11
I have replaced the points, plugs, condenser & ignition wires. I have spark.
I have replaced the battery.
I have replaced the fuel filter.
I have a full tank of gas.
My bug cranks just fiine, but won't "engage". It still won't start.
Next on my list is the fuel pump. First of all, where is it located on the vehicle? Second, can you think of any other possible cause?
I forgot to mention that this is a fuel injected engine.
Sep 10, 2008 at 3:26 AM
DOCFIXIT
  • 18,828 POSTS
Fuel pump is on engine below carb but first check fuel shut off valve on left side of carb. Has a wire to it with key on diconnect and reconnect wire should hear click. If not remove and see if you can free it up . If not plug hole and it should start.
Sep 10, 2008 at 3:41 AM
STAN7_11
I neglected to mention in my original question (now edited) - I have a fuel injected engine (Super Beetle)
Sep 10, 2008 at 3:51 AM
DOCFIXIT
  • 18,828 POSTS
The Super Beetle you a taxing an old mans memory
but I will try. First I reccomend you get a repair manual to aid you. Get some carb cleaner spray into throttle see if it fires. If so then fuel problem.
Is there a silver block with fuel line comming out?
And next to it is a housing with a big screw clamp around it?
When removed is there around metal plate there with a nut in the middle?
I think the pump is under car near the trans. It will look like a silver can couple wires also look for relay under hood.
Let me know
Sep 10, 2008 at 5:54 AM
STAN7_11
When I changed out the fuel filter (under the right front wheel well), I noticed a cylinder a little further down the line. After talking with the VW guy at the local import parts store, I found out that I was looking at the fuel pump.
I do have some carb cleaner at home, so I'll try that later. What's the best way to get into the throttle?
Sep 10, 2008 at 6:01 AM
DOCFIXIT
  • 18,828 POSTS
If system is I described you need to sprak into air intake snorkle
Sep 10, 2008 at 6:06 AM
