1977 Volkswagen Beetle replacing antenna
45,000 MILES • 4 CYL • 2WD • MANUAL
NEAL DAVIS
I have a 1977 VW superbeetle convertible. I need to know how to replace the radio antenna. Do I need to remove the radio first? Is it difficult to get the connector from the antenna to the radio without extensive removal of the dashboard? What steps do I need to follow?
Jan 28, 2008 at 1:11 AM
MIKE H R
  • 3,094 POSTS
you should be able to get to the back of the radio from under the hood where the spare tire and gas tank are as well as the antenna.
Jan 28, 2008 at 1:41 AM
COGNITO
  • 28 POSTS
Lift antenna from body,cut cord ,tape on new antenna. Pull the radio. unplug the antenna..When you pull out the old the new will follow
Mar 12, 2008 at 6:18 PM
