1974 Volkswagen Beetle REAR BRAKES
PAULSTUFF
1974 Volkswagen Beetle 54233 miles
My brake pedal has to much travel, unless I click my parking brake up 4 clicks , then it feels like nornmal braking. Could it be just an adjustment, if so how?
Jan 10, 2009 at 12:59 AM
MAC IN EL PASO
[quote:bb7a33ad23="paulstuff"]1974 Volkswagen Beetle 54233 miles
My brake pedal has to much travel, unless I click my parking brake up 4 clicks , then it feels like nornmal braking. Could it be just an adjustment, if so how?[/quote:bb7a33ad23]
Try the adjustment between the brake peddle and the master cylinder.
Good luck
Jan 13, 2009 at 11:58 AM
JALOPYPAPA
  • 467 POSTS
Also, I think these bugs never had self-adjusters, which on newer drum brakes keep the linings close to the drum as they wear. You need to turn the star adjuster with a screwdriver through the little slot at the bottom of the back of the brake backing plate until the drum tightens up. Then back off a few turns until the drum turns freely. A little rubbing is OK. If your brakes haven't been replaced or serviced in a long time, the star adjusters may be stuck and you'll have to remove the drums, take the shoes and other hardware off and clean and lube the star adjusters.
Feb 17, 2009 at 1:20 PM
