1974 Volkswagen Beetle Oil
LUVITZ56
  • 1974 VOLKSWAGEN BEETLE
  • 4 CYL
  • MANUAL
  • 40,000 MILES
Where in the engine would I need to put the new motor oil?
Thursday, January 31st, 2008 AT 11:38 PM
MIKEYDEP
  • 29 POSTS
If you're just adding oil, to the right and a little
down from your alternator there's an oil cap.
If it's original, it'll say oil or oel. The dipstick is
pretty much right below that.
If you're changing oil.
First remove the plate on the bottom of the engine
and clean it and the screen real good. After the old
oil has drained out, put in the new.
Careful not to over tighten the 6 small bolts for the
plate, they can break easy and you might warp
the plate.
Monday, February 4th, 2008 AT 4:57 AM
