1974 Volkswagen Beetle Ignition Clicks and Wont Engage
2,000 MILES • 4 CYL • 2WD • MANUAL
COWKING7
When I turn the key, I get all the normal lights, but when I turn it to crank the engine, it just clicks. Like the flywheels trying to engage but its stuck. How do I fix this. This happend right after we were taking it out for a drive and the peddle got a little stuck, and it revved to high in 1st gear. Then it just shut down.
Any advice will help thanx
May 29, 2009 at 9:42 PM
BMRFIXIT
  • 19,053 POSTS
Check the oil and make sure its up to the marks
place tranny in neutral E brakes ON ,block tires, try and spin the engine by hand
if engine turn OK
check battery and terminals if OK try to get a jump and suspect bad starter
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 29, 2009 at 9:48 PM
