1974 Volkswagen Beetle i need help
HEARTYP2003
Electrical problem
1974 Volkswagen Beetle 4 cyl Two Wheel Drive Manual
i have changed alternater regulater front wiring harness and it still wont charge any input will be helpful
Jun 19, 2008 at 12:38 AM
DOCFIXIT
  • 18,828 POSTS
Check the field wire on alt. key on see if 12v is present. Exciter voltage from key is need to get alt going. VW runs a wire from batt to ign then back to alt and they often have problem loosing voltage.
Hope this helps
Jun 19, 2008 at 12:57 AM
