1974 Volkswagen Beetle burned points & wiring (not burn
1974 VOLKSWAGEN BEETLE
SLKUHN
As soon as the ignition switch is turned on, the points and wiring completely burn up...literally melt & burn! Starter relay maybe? Never seen this!
May 3, 2010 at 10:24 PM
JALOPYPAPA
  • 467 POSTS
Maybe the points, wire or condenser is shorting to ground. I seem to recall there's a connector on the side of the distributor housing. Maybe there.
May 5, 2010 at 7:40 AM
SLKUHN
Thanks very much for the help! Found the short. Actually, I had a "hot" wire with a constant short to the points' negative connection from the coil.
Thanks again,
Steve
May 7, 2010 at 12:33 AM
JALOPYPAPA
  • 467 POSTS
Good. Glad you're keeping the old bug running.
May 8, 2010 at 11:02 PM
