1974 Volkswagen Beetle Brake light
1974 VOLKSWAGEN BEETLE
200,000 MILES • 4 CYL • 2WD • MANUAL
TSGFTC
The drivers side brake light is very dimmed when the brakes are applied. The left trun signal light does not work. All bulbs have been replaced. The right side brake and turn signal lights are working just fine. Is this problem something interior in the taillight housing?
Thank you
Sep 18, 2009 at 4:23 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Loose or bad ground will cause dimmed and faulty lighting. Inspect the wiring at the lamp housing to ensure it is grounded good.
Sep 18, 2009 at 5:22 AM
