1974 Volkswagen Beetle
1974 VOLKSWAGEN BEETLE
55,000 MILES • 4 CYL • 2WD • MANUAL
ROGERSVW
My 74 beetle stalls when electric choke kicks off?
Plugs look good, put new wires on carb fuel pump and mechanical distributor and the intake boots don't seem to be sucking any air. Your thoughts?
Thank you,
......................Sam Rogers
Apr 16, 2010 at 2:29 PM
DOCFIXIT
  • 18,828 POSTS
Check to see if fuel shut off sloenoid is working. Key on voltage is applied remove wire test for voltage . if present attach wire should hear a click if not solenoid faulty. if that is good then must be debris in idle circuit.
Apr 16, 2010 at 2:48 PM
