1974 Volkswagen Beetle
AUTOMATIC BUG
1974 Volkswagen Beetle 4 cyl Two Wheel Drive Automatic
I have a 1974 VW beetle automatic stick. I used a repair kit on the pic 34 carb, replaced to cracked heads, one fuel pump, one starter, and several seals. When I drive for more than 30 minutes, the engine slowly loses power and shuts down. The car will not start until it rest for and hour or more. then it starts and run as if no problem. Some one suggested that the heat from the engine could be evaporating the gas in the line causing the engine to starve for fuel. I have checked for leaks along the fuel line, blown air through the line, and still have the same problem. Please offer help in correcting this problem.
Aug 14, 2009 at 3:24 PM
BEN ALONZO
as soon as it dies check the basics. fuel in the carb,spark from the coil, had a similar problem all basics were good.but car would have loss of power after driven for short distance. found basic timming was correct but total distributor advance was way out of specs. there for lean mixture and stalling.
Oct 29, 2009 at 11:51 AM
