1973 Volkswagen Beetle Super Beetle 1600
MARKCZ
Engine Mechanical problem
1973 Volkswagen Beetle 4 cyl Two Wheel Drive Manual
I need to remove the dynamo to change bearings.
It wont come out backwards because the fan
backplate jams against the manifold.
How does one remove the dynamo??
Thanks
Feb 24, 2009 at 7:49 AM
JALOPYPAPA
  • 467 POSTS
I remember replacing a generator and I don't think I removed the manifold. Is the problem that the fan won't clear the shroud? I think maybe you can loosen the shroud from the sheet metal on the cylinders and maybe shift it enough. Maybe if nothing else remove the hood and pull the whole thing straight up.
Feb 25, 2009 at 10:58 AM
