The park brakes do not catch so I have no park brakes. How do I repair? Is there a diagram somewhere?
Jul 2, 2008 at 3:09 AM
DOCFIXIT
✓Experienced Mechanic
There is an adjustment at the handle pull up rubber boot you will see threaded rod[two] loosen front and rear nut turn front in this will tighten. Pull lever up 5 clicks adjust till car does not roll. This is if cables are not rusted frozen and mechanism on wheel is functional.
Happy motoring
