1972 Volkswagen Beetle My 72 Beetle won't start.
BWRICKS
  • 1972 VOLKSWAGEN BEETLE
Engine Mechanical problem
1972 Volkswagen Beetle 4 cyl Two Wheel Drive Manual? Miles
I have replaced the started and the ignition switch. When I turn the key, I just get one click (as though it has a dead battery). I don't think there is a ground problem and all of the fuses are fine. What do I check next?
Monday, January 11th, 2010 AT 11:01 PM
DR LOOT
  • 2,311 POSTS
Make sure that the starter is not binding against the flywheel, if it's making a one click it sounds like it's engaging and then it gets jammed.
Due to the high volume of no responses to posted questions, if you have not resolved your issue and you need further assistance, please respond.
Tuesday, January 19th, 2010 AT 10:40 AM
