1972 Volkswagen Beetle
JINXY
Engine Mechanical problem
1972 Volkswagen Beetle 4 cyl Two Wheel Drive Manual
Hi i have just replaced the air filter and crankshaft pulley on my 72 beatle, after putting the new ones on and putting it back together, and starting it, it just does not sound right it sounds alot rougher and that i think some thing might be grinding or rubbing. Any ideas. Please help!!!!!
Jul 7, 2008 at 10:13 PM
JALOPYPAPA
  • 467 POSTS
I assume you've turned the engine over manually checking the pulley for any rubbing against the shrouding. I can't remember whether the oil slinger on the crankshaft extends any way through the case. I do seem to recall a washer behind the pulley bolt.
It just seems most likely something's not quite right with the way the pulley is on there. maybe the hub is somehow rubbing against the case.
Jul 12, 2008 at 3:42 PM
