1971 Volkswagen Beetle intake manifold boot replacement
SORRELLSG
Engine Performance problem
1971 Volkswagen Beetle 4 cyl Two Wheel Drive Manual ? miles
I have been advised to replace the intake manifold boots on my car to eliminate an engine miss. Is there an easy way to do this?
Feb 12, 2009 at 2:05 AM
JALOPYPAPA
  • 467 POSTS
I think you could remove the carb, loosen the center part of the manifold and slip a boot in. You'd have to get the heat risers loose, and those bolts sometimes are rusty, so I wouldn't count on it being easy.
Feb 17, 2009 at 1:05 PM
