1970 Volkswagen Beetle it was setting for five years and th
SJACKSON1970
1970 Volkswagen Beetle Manual
i dont know were to start with it. i dont know nothing about the older cars but i do know somewhat to do with the newer ones.
Jan 5, 2009 at 1:56 PM
  • 31,937 POSTS
Hi there,
Just drain the oil, and take the plugs out, squirt a little oil in each cylinder and with the oil replaced crank over till oil pressure is up, replace the fuel filter and you may have to clean out the carby as it will have dried out and it could be a bit fuzzy in side, that should be enough for the engine side of things, post here for more info if required.
Mark (mhpautos)
Jan 5, 2009 at 2:01 PM
