1970 Volkswagen Beetle Could the engine be frozen
1970 VOLKSWAGEN BEETLE
TONYNEAL
  • 37 POSTS
Engine Performance problem
1970 Volkswagen Beetle 4 cyl Two Wheel Drive Manual
I have a 1970 VW Beetle, not sure of engine size, possibly a 1600cc. This is my first VW.
I consider myself a decent mechanic, trained by my dad who was certified, and in my opinion, an expert. I would usually ask him for advise but he passed away a few years ago.
So let me begin with the events leading up to the problem.
One afternoon, while taking off at stop sighn the engine died, it started back up but seemed kind of sluggish. I gave it more gas and while pulling out into the roadway it seemed like the brakes where stuck on, and the engine slowly died. Then, when I tried to restart it, all I hear is the starter click.
My question is this, Could the engine be frozen? And if so, can I fill the spark plug holes all the way with oil, and by using another vehicle, push it in reverse to free it?
One guy suggested filling the cylenders with bleach. I don't know about that?
Have any ideas that might work?
This is our only car and summer in Arizona is no time to be without!
Jun 19, 2008 at 8:58 PM
BLACKOP555
  • 10,386 POSTS
could be frozen, check for the oil, have you noticed low oil pressure? take and put it in gear and have soemone push you mark the harmonic balancer or belt and have someone push the vehicle, if the mark moves then the engine probably isnt frozen and chances are the battery was probably low and not charging which caused it to die out, and now just click.
Jun 20, 2008 at 8:04 AM
BLACKOP555
  • 10,386 POSTS
i wouldnt put oil in them either to fill them, if you put too much and you go and crank it if it wasnt frozen it will be after you do that. a teaspoon of oil will be fien, but not 1 cup!
Jun 20, 2008 at 8:05 AM
DOCFIXIT
  • 18,828 POSTS
Don't know about all that pushing just pop the engine cover get a big cresent wrench place it on the crank and turn.
I going to say number 3 piston melted to cyl sleeve.
Jun 20, 2008 at 8:48 AM
BLACKOP555
  • 10,386 POSTS
it can be hard to turn by hand sometimes. i prefer to push, always have!
give um both a go. and bleach is a no no.
Jun 20, 2008 at 1:12 PM
