i replaced the fuel pump. i took the gas tank off and drained it and blew out the lines and tank. i replaced the spark plugs. i took off new wires off my '66 vw and put them on the '67 no difference. i took off the coil off the '66 and put it on the '67 no difference. checked my fuses,nothing. it just won't run. it will try to turn over put no spark. i even try to see if any spark from spark plug by taking the end of one spark plug connector and holding it 1/8 from engine but no spark. i even took off the coil wire from the distributor cap and see if any spark but none. can you help me brainstorm this situation.
Sep 29, 2008 at 4:36 AM
