1964 Volkswagen Beetle
1964 VOLKSWAGEN BEETLE
36,000 MILES • 4 CYL • 2WD • MANUAL
STEVENP
I have a 1600 vw engine, I'm having one rocker arm that keeps going out of adjustment. I check rocker and adjustment screw and nut, they are fine. It’s there some thing internal going on. I’ve been a bug owner for 34 years and never had a problem like this
Jan 27, 2008 at 6:32 PM
MIKE H R
  • 3,094 POSTS
loosen the nut, then back the screw out, look at it to see it the threads are worn. It probably be better to take the arm off. It would be easier than trying to see if the threads are bad on the screw or rocker. Other than that, with everything tight and the lock nut tight I can't think of anything.
Jan 28, 2008 at 4:48 PM
MIKEYDEP
  • 29 POSTS
i would check the head studs too...
make sure they're torqued properly,
Feb 4, 2008 at 5:01 AM
COGNITO
  • 28 POSTS
Check for a loose cyl head,compare valve spring heights[possible loose valve seat].Almost all after market adjuster screws are too soft and cause excessive clearance soon after adjustment.
Mar 12, 2008 at 11:12 PM
