1960 Volkswagen Beetle alt
46,725 MILES • 4 CYL • 2WD • MANUAL
HEINZ
i put in a new alt but it only lasted about 2 weeks.
now the dash light is barley on , and the alt is putting out 19.04 to 19.23 volts at an idle.
and when more than a idle it goes down to about 18.33 volts when running.
other wise its over charging.
what to do ?
the dash lite is brite before starting,
then is suposed to go out when the engine starts.
and it does but now the lite element barley glows orange.
Feb 28, 2009 at 3:08 PM
  • 31,937 POSTS
Hi there,
The alternator is over charging my a considerable margin, you will need to get the voltage regulator checked, not sure if it will be internal or external on this early converted VW.
Mark (mhpautos)
Feb 28, 2009 at 3:20 PM
