How long would you say that 2-3 mm front brakes should last?
110,000 MILES • V6 • 2WD • AUTOMATIC
TEEKEE24
Hey, I don't think I have to panic, but how long would you say that 2-3 mm front brakes should last? Les Schwabb did a visual inspection. I drive maybe 20-30 miles a month.
Sep 3, 2022 at 12:02 AM
  • 55,743 POSTS
Under normal braking conditions they should last about 5,000 miles. here is how you can replace the front brake yourself and save some money. The pads will cost $30.00 link below.
https://amzn.to/3KI1drO
Also here is a guide to help you raise the car and remove the wheels. Go over the guides before you begin.
https://www.2carpros.com/articles/wheel-removal-and-re-installation
and
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Sep 3, 2022 at 1:24 AM
