Vibrations with Malfunction Light on
104,000 MILES • 6 CYL
JAY JJ
Started the car. Observed vibrations of the engine with the Malfunction Indicator Lamp came on. Checked for the fuel and fuel cap. Okay no problem there. What does this mean?
Feb 14, 2016 at 8:39 AM
WRENCHTECH
  • 20,758 POSTS
The "check engine" light is an indicator for a system that monitors many electronic functions in the system, also called the "malfunction indicator lamp" (MIL). It can come on for any of hundreds of different causes from any of the systems that the computer monitors. Some are very important and can lead to further component or engine damage and some are emissions related not as serious but still a problem and need to be repaired.
Your first step is to have the computer scanned to retrieve the trouble codes that were set when the check engine light came on. Those codes will give you specific information about what the computer saw and will get you pointed in the right direction to find your problem. With a 1996 or newer and some 95 cars and you have an AutoZone or Advanced auto parts in your area, they will read them for free. Once you have these code numbers, we can be a lot more specific about what your problem may be.
Feb 14, 2016 at 9:10 AM
