Vibrations when driving, check engine light on?
188,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
JACKMASON34
  • 6 POSTS
The major problem is some pretty severe vibrations happening while driving. The vibrations are intermittent and only last for a few seconds at a time. The time between vibrations is inconsistent. Sometimes they are seconds apart or minutes apart and sometimes it is just one vibration while other times there are several rapidly, one after another. The vibrations are felt throughout the truck, particularly through the seats. It feels like you are driving over a rumble strip, but much worse. Driving speed doesn't seem to be a factor, but going up steep hills seems to reliably produce the vibrations. It doesn't seem to affect the steering or to be from a steering component. Some other symptoms that may or may not be related are as follows:
There is a check engine light on. The light has been on pretty much since the week I bought the truck 4 years ago. I took it back to the small, independent dealer I bought it from, and they said they couldn't figure out what the problem was. The truck drove fine though, so I didn't worry about it too much. About 2 years ago I took it to an actual Ford dealership to get fixed. The code was for a cam position sensor. I had them fix it but almost as soon as I drove away from the dealership the check engine light came back on. I haven't had the time or money to get it looked at again since then, but now that these vibrations have started and have quickly gotten worse, I am concerned what might happen if I don't get to the bottom of this and get it fixed for good.
Very occasionally the truck will shift hard when going into reverse, with a bit of a clunk, but it seems to shift fine going through all forward gears. I haven't noticed any clunking or hesitation when the truck shifts between gears while driving and all gears seem functional.
When starting the truck from cold, the engine oil temperature goes immediately to just over the midway point between "L" (low) and "H" (high). Bad sensor? Could it be related to the vibrations, I don't know?
RPMs don't seem to go much over 2,000 even when going uphill unless I really give it the beans, but I don't know if this is unusual and when I do give it a good dose of gas the RPMs do go up to 4,000-5,000, seemingly as they should. I haven't noticed any hesitation when taking off from a stop or when I give it gas to accelerate quickly for things like passing. RPMs do seem to fluctuate slightly though when the truck vibrates, maybe by a couple hundred RPM.
I have had one person suggest to me it could be the drive shaft or a differential, but I don't know. Seems it could be the engine. Maybe a bad camshaft? Maybe the timing belt is slipping? Maybe it's the transmission?
I would appreciate any advice on how to nail down whatever is causing the vibrations. I will likely have to fix this problem myself and I don't want to spend the money on parts until I know for sure what is wrong, but I'm not that great at diagnosis yet. My gut tells me either an issue related to a camshaft or the transmission, but I need to be positive about the cause. I can't afford to guess.
Oct 19, 2023 at 2:54 AM
  • 110,248 POSTS
It could be a universal joint on the driveshaft. If you are sitting still and shift from drive to reverse and back, do you hear a clunk? Let me know. Also, here is a link that explains how to check a universal joint:
https://www.2carpros.com/articles/how-u-joints-work
Also, since the check engine light is on, it could be engine related. For example, there could be a misfire in one or more of the cylinders. I'm not sure where you are located, but most parts stores will scan the computer free of charge and let you know what codes are present.
Does the check engine light ever flash when you notice this issue? When was the vehicle last tuned-up?
Let me know. Also, if you can, have the computer scanned at a parts store and let me know what codes are found.
Oct 19, 2023 at 11:39 AM
JACKMASON34
  • 6 POSTS
I just bought a code reader. I should have bought one years ago anyway. The CEL doesn't flash at all. There are two codes in the system. P1450 and P2019.
P1450 is an EVAP code. From my brief research it is caused either by a bad fuel tank pressure sensor or a bad purge solenoid. I don't imagine either way that this would be causing the vibrations. I don't see how it could. Maybe I'm wrong though.
P2019 is coming back as "intake manifold position sensor or switch circuit bank 2". I again did very brief research and what I have found is that this could be caused by a bad sensor (not sure yet which sensor exactly or where it's located) or the entire intake manifold itself could be damaged and need to be replaced. Why in the world they would make an intake manifold for a truck out of plastic, I don't know. What is even harder to understand is how Ford is charging $700 for factory new ones. That's 70% of the cost for a whole new set of heads, complete with valves, camshafts and hardware, for a bunch of plastic pipes. Anyhow, gripes about Ford aside, I think I read that this fault could starve the engine of oxygen and cause power loss at higher RPM, or cause the engine to not want to go into the higher RPM range. I might be experiencing that, but I'm not sure. Even if that is happening though, it definitely doesn't coincide with the timing of the vibrations. I don't know if this could still be causing vibrations some other way though. Could this cause misfiring? Would misfiring cause the vibrations I'm feeling?
I did the test shifting from drive to reverse and back again several times on a level surface and didn't experience any clunking. Once in a while, if I'm on an uphill incline, even a slight one, shifting from park to reverse might cause a slight clunk but it doesn't seem serious and doesn't always happen. It's only occasional.
I haven't had a chance to get under the truck and check the universal joint yet. Bad weather and busy schedule. I will climb under there the first chance I get though and see what I can see.
I don't really take the truck for complete tune-ups ever. I try to make sure the oil gets changed every 3k miles, but I admit sometimes I'm not very timely with it. I do brake pads when they need it. I pretty much just do regular maintenance things when the need arises. I did just take it in for a professional oil change this week though and they also put in a new air filter and topped off the coolant. It has brand new tires, new outer tie rods, fresh alignment, new brake pads and rotors all around, front calipers are new, and the rear parking brake on both sides is newly repaired.
Some other suggestions I have gotten:
-Put the truck into neutral and run the engine at 2-3k RPM. If it doesn't reproduce the vibrations, it's probably not a problem with the engine. I tried this and it didn't produce the vibrations I've been feeling. It seemed hard to keep the engine steady at a certain RPM. I tried like hell to keep my foot steady and hold the gas pedal at a fixed position but I could only hold it at 2k RPM for a short time before it would either climb quickly to 3k or drop quickly to 1k. Maybe it's just me not being able to keep the gas steady, or maybe the engine isn't able to stay at a certain RPM? I don't know though and I'm not sure what that might indicate if it's the engine and not just me. If it's just me then it would seem the engine isn't the problem?
-A bad differential. I have never dealt with differentials before. I generally know what it does and that it involves different gears but I don't know enough to know how to check to see if one is bad.
-Rear axles or drive shaft. My wife got hit in a rear end collision recently, which I know can cause damage to the drive shaft or axles. However, after the accident I had a Ford dealership I really trust look the truck over for any damage that wasn't just body damage. They did their standard multi-point inspection and said everything checked out. After that I had the brakes all done, including the parking brakes because apparently there was a problem with the parking brakes that damaged the ABS sensor and gave a bunch of warning lights on the dash. I guess part of repairing the parking brakes involved removing the rear axles and taking the rear differential apart. I would like to trust that if there was a problem with either it would have been noticed and I would have been notified, and I would like to trust that they put everything back together properly. But, they seem to have some dishonest business practices, and they also screwed up installing brake pads on one of my brakes and it was causing the wheel and lug nuts to get extremely hot. Took a while to figure that problem out. So, maybe they screwed up on the diff or axles as well?
I don't know what you think of any of those possibilities, if they could cause the vibration I'm feeling or the slight fluctuation in RPM when the vibrations happen? I could very easily be wrong but it doesn't seem to be an engine issue or a transmission issue.
Oct 20, 2023 at 6:04 AM
  • 110,248 POSTS
The P2019 is related to the intake manifold runner switch, bank 2. If it isn't working properly, you will experience engine issues. Also, the EVAP code is related to excessive fuel tank vacuum. At this point, my theory is the issue with the runners may be causing the additional code.
If you look below, I attached the diagnostics for the P2019 code. I skipped the portions related to bank 1 because of the extent of the tests. Take a look through them and let me know if you are comfortable performing them.
Oct 20, 2023 at 8:07 AM
