vibrations at low RPM e.g.when idling
130,000 MILES • 2.0L • 4 CYL • RWD • MANUAL
THEPCMANIACCC
very strong vibrations are felt at low RPM . Can the EGR valve cause such a thing or something else is liklier?
Apr 16, 2014 at 6:49 AM
  • 110,248 POSTS
The EGR can cause issues. However, there are many other things that can do the same thing. Tell me, is the check engine light coming on? When was the last tune up?
Apr 23, 2014 at 4:45 AM
  • 110,248 POSTS
Also, let me know if you checked for vacuum leaks and the idle air control valve. Plus, let me know the RPM's in which the engine idles.
Apr 23, 2014 at 4:46 AM
THEPCMANIACCC
Vibrates at idle (~800rpm).Haven't checked for vacuum leaks or idle control valve.
Apr 23, 2014 at 4:52 AM
THEPCMANIACCC
also no lights coming on
Apr 23, 2014 at 5:37 AM
  • 110,248 POSTS
Since there are no lights coming on, that is a good indicator that the problem isn't related to a sensor or a misfire issue. You mentioned that you notice it mostly at an idle. Therefore, I need you to start with the basics. Check to see if there are any vacuum leaks that can be causing the rough idle. If the idle is erratic and doesn't stay around 800 rpm's, then check to make sure the IAC is working properly.
Apr 23, 2014 at 10:32 PM
