Vibration with compressor on
102,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
IHAVETHREEFORDS
I just recently had all three motor mounts replaced on our car. It helped a little with the vibration/feedback in the steering wheel. However, whenever the auto climate control, or the defroster, or ac is running, and the compressor is on and drawing, it significantly increases the amount of vibration in the steering wheel. I was hoping the new mounts would decrease it a bit but it hasn't. AC blows cold, everything within the climate control system is working great. Is something failing? Perhaps it needs another recharge? Is there anything I can do to remedy this?
Nov 28, 2019 at 1:55 AM
  • 110,248 POSTS
Is there any noise associated from the compressor? Also, I need you to pay attention to the engine RPM's when you feel the vibration. If the RPM's are dropping too low, that will cause what you feel.
In the throttle body is what is called an idle air control valve (IAC). This component is designed to maintain idle speed. When an extra load is placed on the engine such as the AC, the IAC allows the idle speed to increase to compensate for the load. If it isn't working, the RPM's may be dropping too low. This is just a theory at this point.
Nov 28, 2019 at 11:23 AM
IHAVETHREEFORDS
Thanks Joe, there is no discernible difference in RPM's with or without compressor on. It stays at a very steady 600 rpm's once the engine is warmed up. There is a noticeable, quick, "grunt" noise whenever the ac/defroster is turned on, but only lasts half a second and everything runs normally otherwise. It has been doing this for quite sometime (9-10 years) and the dealership called it normal operation, for whatever that's worth......
Would some basic maintenance things help, like checking/charging the level of refrigerant or maybe a throttle body cleaning?
Dec 1, 2019 at 11:26 AM
  • 110,248 POSTS
Anything is possible. It wouldn't hurt to check the AC system high and low side pressures to see if something is happening there. However, if it has been that long, I would think it isn't and issue. If the RPM's are at 600 with a load on the engine, that is a bit low. It should be closer to 800. Cleaning the throttle body may not be a bad idea. If it idles at 600 with or without the AC running, the IAC seems to be doing its job, but the idle itself seems low.
Here is a link showing how to service the throttle body. Let me know if it helps.
Also, I really question of the idle air control valve (IAC) may not be working as it should. Take a look through this description of its job and what it is responsible for (toward the bottom of the article.
IDLE AIR CONTROL (IAC) VALVE
NOTE: The IAC valve assembly is not adjustable and cannot be cleaned, also some IAC valves are normally open and others are normally closed. Some IAC valves require engine vacuum to operate.
The IAC valve assembly controls the engine idle speed and provides a dashpot function. The IAC valve assembly meters intake air around the throttle plate through a bypass within the IAC valve assembly and throttle body. The PCM determines the desired idle speed or bypass air and signals the IAC valve assembly through a specified duty cycle. The IAC valve responds by positioning the IAC valve to control the amount of bypassed air. The PCM monitors engine RPM and increases or decreases the IAC duty cycle in order to achieve the desired RPM.
The PCM uses the IAC valve assembly to control:
- no touch start
- cold engine fast idle for rapid warm-up
- idle (corrects for engine load)
- stumble or stalling on deceleration (provides a dashpot function)
- over-temperature idle boost
The problem with the IAC on this vehicle, it can't be serviced. By the way, I looked up idle speed and it indicates it should be right around 775 RPM's. Honestly, if it was increased to that point, the vibration wouldn't be as noticeable.
I will watch for your reply. Let me know if any of this helps.
Dec 1, 2019 at 2:48 PM
