Engine Vibration
129,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
NASCARWOW
  • 10 POSTS
I recently needed a flex pipe repair and took it to a muffler shop for replacement. I assumed they would replace the entire flex pipe (the same part per OEM) from flange to flange. Instead they cut out the flex part of the pipe and welded in a new flex section.
When I picked up the car it had a bad vibration when the transmission is engaged. It is especially bad when the engine is cold an in reverse. The vibration lessens when the engine warms up.
The vibration did not occur before the repair. The shop insists it is unrelated to the repair and must be caused by something else.
Is the rigged flex pipe repair the cause or is it something else and if so what would it be?
Jan 3, 2019 at 2:00 AM
KENW1
  • 213 POSTS
Hello, thanks for stopping by 2CarPros. It's possible that they welded on the pipe with the battery connected which can cause ECM issues. Other than that It could possibly be a loose motor mount that they may have loosened while working on it, although the repair procedure from the factory does not note removing or loosening any motor mounts.
Jan 3, 2019 at 7:13 AM
NASCARWOW
  • 10 POSTS
If the ECM were an issue, wouldn't there be check engine codes? The check engine light is not on and the car seems to idle fine in park and neutral.
Jan 3, 2019 at 7:59 AM
KENW1
  • 213 POSTS
Some sensors can be damaged or parts of theECM that read those sensors and cause a slight misfire that does not register. You would need a scanner to access live data and look specifically at the MAF air flow, O2 readings, fuel trim, and misfire counter to see if an anomaly exists. I would ask them if they happened to loosen an engine mount as well as a loose one can mimic rough running.
Jan 3, 2019 at 8:18 AM
  • 55,540 POSTS
If they welded or connected the flex pipe in at a tension angle it will telescope to the frame through the exhaust and engine mounts. I would jack the car up and take a video or picture so we can see what is going on. This guide will help you lift the car safely.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Please let me know what you find. Adding to KENW1 here is a guide that will walk you through the steps to get the codes if any:
Cheers, Ken
Jan 3, 2019 at 9:35 AM
NASCARWOW
  • 10 POSTS
Thanks for the responses. I will try to get a video this weekend when there is some natural light.
Jan 3, 2019 at 11:19 PM
  • 55,540 POSTS
Please do, we want to get this fixed for you.
Jan 4, 2019 at 2:15 AM
NASCARWOW
  • 10 POSTS
I was having trouble uploading videos, so I have included links below.
Here is a close up of the repair from the engine compartment:
https://drive.google.com/file/d/1joh3IScye0ZIrfO6iV6nmmU8vsjY7mVD/view?usp=sharing
Here is a video with the car idling in park:
https://drive.google.com/open?id=11Zl_Wnk9yooymuk3t9sq1Fyz8I2fGxQg
Here is a video with the car in reverse. I took it with my new phone. The engine/exhaust is actually shaking but I think the video smooths it out where is looks more like swaying. Sorry I am not familiar with how to change the settings.
https://drive.google.com/open?id=1e9q5XPtEx9M0MVLNdXRBgxzuoYBMQ7lp
I have a code reader. I can check for what was described above tomorrow.
Jan 8, 2019 at 1:15 PM
  • 55,540 POSTS
Thanks for the videos. Yep, you can tell the exhaust system is pushed downward because the flex pipe they installed is too long. I also see the weld? looks like bubblegum. I would take the car somewhere else to have the repair redone correctly.
Can I ask what kind of problem you had uploading the videos? What phone or operating system do you have?
Please let me know what happens.
Jan 9, 2019 at 2:03 AM
NASCARWOW
  • 10 POSTS
I was wondering about the length being the issue. Over the weekend I ordered the correct entire flex pipe through on online order which I received yesterday. I was going to compare it to the installed pipe to see if that was an issue. I also thought that the weld looked like garbage. In the photo you can see it has a crack.
A few years back the shop installed a full dual exhaust for my 1970 Torino GT. They did a great job. I suspect the shop has been sold since the manager that was there for many years was not there when I took the Fusion in.
I will report back.
Jan 9, 2019 at 9:45 AM
  • 55,540 POSTS
Please do, I think we are on the right track. Thanks for the video issue input btw :)
Jan 10, 2019 at 3:40 AM
NASCARWOW
  • 10 POSTS
I can finally report an update.
I was avoiding the repair since I don't have a garage available and the driveway is pretty cold here in Michigan. But I remembered that my brother has a lift in his garage and it is heated. (What a blessing!)
The good news. I was able to replace the flex pipe without breaking any bolts or other frustration. I was also able to get a refund from the repair shop. The new flex pipe resolved the extreme vibration when the transmission was engaged.
The bad news. When the engine idles in park/neutral it is smooth and when the engine has not come up to full operating temperature the car idles pretty smoothly for a four cylinder at about 900 rpm in reverse/drive. However, when the engine gets to full operating temperature the idle drops to around 600-650 rpm and I have a vibration. (It is not as bad as what I was experiencing with the original flex pipe fix.) Still, it is noticeable enough that is is annoying.
FYI, when replacing the flex pipe I did not anticipate needing to remove the exhaust manifold but it was necessary since the upper flex pipe nuts where not accessible without removing the exhaust manifold with the flex pipe as one unit. When removed together, I could replace the flex pipe. As a result, I did not have a new exhaust manifold gasket or new studs which I have read is the proper procedure after removal. I don't know if this could contribute to the idle issue.
While this is an improvement overall, I am still not satisfied with how the car runs currently. Any other suggestions?
Thanks.
Feb 7, 2019 at 9:42 AM
  • 55,540 POSTS
Yes, this is a balance shaft engine which could be worn or broken not cancelling the engine vibration. Here are instructions for checking the balance shaft component of the car. Check out the diagrams (below). Please let us know what happens.
Feb 8, 2019 at 4:45 AM
NASCARWOW
  • 10 POSTS
After I wrote my update, the car idled very well over the weekend. I was pleased. Today it seemed more like it had been. Confusing.
I don't think that I will spend $400.00 for the dial indicator in the instructions. Looking at replacement parts I could replace the whole balance assembly for under $200.00.
I assume this assembly is at the bottom of the engine. Does the engine need to be pulled to check or replace the balance shaft?
Feb 11, 2019 at 8:49 AM
  • 55,540 POSTS
If the balance shafts are a problem it vibration would not come and go and it would be noticable. The engine oil pan needs to come of to check the condition of the balance shaft module.
Feb 12, 2019 at 1:46 AM
